SC00TA
Nov 30, 2021Tutor
Xr300 poor speeds
Hey guys I am based in New Zealand, and have recently changed over to a fibre max plan wich i should be getting speed of up to 860 down and 501 up. but I am lucky if I am getting 150down and 70u...
SC00TA
Dec 01, 2021Tutor
when I do a speed test through the nighthawk app, it is showing 150 down 76 up, but this fluctuates quite a bit and will often drop
see below
Netduma-Fraser
Dec 01, 2021NetDuma Partner
Can you attach a screenshot of the table view on the Device Manager please?
- SC00TADec 01, 2021Tutor
Im at work now, but will respond with the screen grab as soon as I can
- SC00TADec 05, 2021Tutor
see device manager below
- Netduma-FraserDec 05, 2021NetDuma PartnerWhatever you had connected to the LAN port in the first screenshot is limited to 100 Mbits, either it's the ethernet cable or the ethernet adapter on the device is limited to that speed
- SC00TADec 05, 2021TutorThat would be my fibre box which is connected via Cat6 cable
