atomicdroid
May 04, 2022Follower
XR300 reboots randomly. Where are retained logs kept?
greetings, My XR300 has been randomly rebooting. I logged in to look at logs to see what the culprit might be. But when I look at the log it only contains entries since reboot. Where are the ret...
Netduma-Liam
May 05, 2022NetDuma Partner
Logs are stored in memory and are cleared when power is lost.
Does the connection come back itself, or do you need to do something manually to get the connection back?
Are you able to access the DumaOS interface when the connection is dropped?
Are the lights on the XR indicating that it's rebooting or do you believe it's dropping because the connection is dropping?
