SaltySenpai
Mar 19, 2021Aspirant
XR300 Router having trouble keeping uploading speeds
So, I've had this router for less then a year, well, damn near a year. Though, as of 2 days ago, its upload speed has dramaticly dropped. I'm normally hitting 10 Mgb/s, but as of late, i'm barely hit...
- Mar 19, 2021
What arris is it?
Have you went in to the XR and manually set you upload speed?
SaltySenpai
I had done that. Connecting to the modem which is an Arris Surfboard the speeds jumped back up where they were ment to be at.
Mar 19, 2021Guru - Experienced User
What arris is it?
- SaltySenpaiMar 19, 2021Aspirant
The Arris is an SB6183.I'm not sure what you mean by manually setting my upload speed.
- Netduma-FraserMar 19, 2021NetDuma PartnerAs it's the first time it's happened and assuming you didn't change anything give the router a reboot to start with from the interface and see if it goes back to normal.
