SinfulWraith
Oct 23, 2020Tutor
XR300 Self Rebooting
Hello everyone I've come to the posts due to phone support couldnt fix the issue so far and a newab unit from RMA was was over nighted for $30+. Due to working from home and needed the issue fixed. s...
SinfulWraith
Oct 23, 2020Tutor
I haven't checked with it not connected to the modem. The way I know it is disconnecting is everything lan and wireless gets disconnected. Lights on xr300 go off and back on as if the reboot was pressed as in Duma OS. My security system tells me when and when not there's internet connected.
Oct 23, 2020Guru - Experienced User
Did you try a different outlet?
Did you replace the power supply at the same time? Or just the router portion of the device when they rma'd it.
- SinfulWraithOct 23, 2020TutorI changed out the power supply for the nighthawk along with the outlet and brand new surge protector.
- Netduma-FraserOct 23, 2020NetDuma PartnerWhen it next happens watch to see if the power light actually goes off and comes back on again as disconnecting all devices will be very different to that.
- SinfulWraithOct 23, 2020TutorPower light dims and internet light goes orange and one of the internet port are still white.
