RikMeleet
Jan 20, 2021Aspirant
XR300 slow internet speeds
My router only gets 80mbps when I use it. I checked the settings and tried different settings. When I put the router in AP mode I get a average of 380mbps. This is all on WiFi. Wired is the same excep...
Netduma-Fraser
Jan 20, 2021NetDuma Partner
It sounds like your QoS Settings, in the Anti-Bufferbloat panel, click the 3 line icon in the top left and disable it completely. What speeds do you get then?
- RikMeleetJan 20, 2021AspirantThank you for the fast response, unfortunately disabling the QoS makes no difference at all. Still around 80mbps. Tested all my cables from the router to the modem, replaced them with new ones. Any other suggestions I can try?
- Netduma-FraserJan 20, 2021NetDuma PartnerOkay interesting, what do you get via ethernet to the XR?
- n4sh23Jan 23, 2021AspirantXr300 have a vlan problem,don't use vlan on this router and your internet speed return
