JAMSROO7
Nov 21, 2019Guide
XR300 trying to bridge a tplink w9970
Hello I’m trying to bridge a tplink w9970 with a XR300 Gaming router, but when I try to access the netgear menu it just keeps spinning the loading logo any tips please thx.
JAMSROO7
Nov 22, 2019Guide
Thx bro i’ll Try that.
Nov 22, 2019Guru - Experienced User
Hopefully they have a user manual for there product.
- JAMSROO7Nov 22, 2019Guide
Thx m8 i’ll Go down the tplink route, one thing when I first tried to set up the router it asked me 2 security question’s which I ga e answers to but when I try to put the answers in it said wrong answers, now I can’t even find that option, sorry if I’m being vague, it should be such an easy thing to do I just can’t see why I can’t acsess the router settings even though I can get on the routers network with ps4 and iPad.
- FURRYe38Nov 22, 2019Guru - Experienced User
Did you walk thru the setup wizard with a wired PC and web browser? Might try a reset and setup from scratch. Use a wired PC and web browser to walk thru the setup wizard. Be sure to write down all important information for safe keeping.
- JAMSROO7Nov 23, 2019Guide
That’s the thing bro i’ve Only goy ps4, and I pad to work with. So you think if I use tp link as a bridge and have wired connection To rx300 through laptop or pc I could get it to work.
