JAMSROO7
Nov 21, 2019Guide
XR300 trying to bridge a tplink w9970
Hello I’m trying to bridge a tplink w9970 with a XR300 Gaming router, but when I try to access the netgear menu it just keeps spinning the loading logo any tips please thx.
Netduma_Alex
Dec 04, 2019NetDuma Partner
JAMSROO7 wrote:
Hi Alex, yea I have talk talk internet and the Rx300 has no vdsl port
Oh yeah you'll need a modem. The XR300 isn't a modem.
JAMSROO7
Dec 13, 2019Guide
Do you think trying to bridge the w9970 tplink and the Rox will increase ping, would I be better off trying to get the model no. With a modem as I’m in the k with talk talk internet and if so what’s the best netgear model to get for my needs, thx Alex.
- Netduma_AlexDec 13, 2019NetDuma Partner
Either bridging your existing router/modem, or using DMZ to connect all of the downstream stuff. Both of those solutions would work fine.
If you wanted a VDSL Netgear router, this would fit the bill: https://www.netgear.com/home/products/networking/dsl-modems-routers/DM200.aspx
It doesn't need to be a Netgear modem though.
- JAMSROO7Dec 16, 2019Guide
Alex mate I have laptop now, if I can’t get bridge mode to work can I try ap mode to link the w9970 and the rx300 any tips massively appreciated, laptop doesn’t have Ethernet port so I’m trying with 2 routers linked Ethernet cable, thx pal, just info on op addresses and dns.
Just had a 25minute live chat with tp link, at the end they said they cant do anything for me as there not familiar with the netgear router loool grrr. All I need to do is put the tplink in bridge mode and try use the nighthawk, which when I follow the right guidelines isn’t letting me acsess the nighthawk network,tried everything bro.
- Netduma_AlexDec 16, 2019NetDuma Partner
Perhaps there's some clash happening between the IP addresses of the devices. Perhaps you need change the XR300's IP address to something totally different like 192.168.3.1 and then put the other device in bridge mode
Bro that’s the thing if I try bridge mode, and leave the wireless acsess on I can do a few bits, but in the instructions it says to leave wireless acsess off when using bridge mode, so basically I’m doing it wrong, and getting nowhere fast, last night I got through to netgear support, and a guy used fix me with remote acsess to try solve the issues, at the end of it he said I had foreign ip addresses on my network and this was causing the issue, trying to acsess the netgear router page, wanted 149pounds to fix it! I don’t know how legit this was but said I couldn’t pay that, he said that’s why I’m getting issues when gaming even tho I’m hard wired with wireless turned off when I’m using tp link on its own does this sound true to you Alex, once more thx for all the advice, if I can try the tp link AP mode, don’t think I can tho, any tips on ip and dns m8.
Guys thankyou so much for all your support but I am officially giving up lol, I’m gonna buy a router that works vdsl. Could you please let me know what model is closest to the rx300, as the only reason I went for that model is it had such a glowing review from a guy on utube called John glasscock, who said it’s perfect for PS4 gaming, but if you don’t want loads of expensive features this model is perfect once more many thanks for your time.
- Netduma-FraserDec 17, 2019NetDuma PartnerI'm not sure if this is the issue or not but disconnect the XR from the TP Link and then access the XR router via ethernet - can you access it correctly? If so make sure it's in router mode and then in LAN Settings change the LAN IP to something like 192.168.10.1 then apply and reboot the router. While that is rebooting connect to the TP Link and remove the bridge mode, connect the router back to the TP Link and re-establish the bridge mode. Then connect to the XR WiFi and try to connect to the interface using the LAN IP you changed it to, does that work?
I couldn't recommend one similar really as the XR series are the only routers that have DumaOS/these kind of features. - JAMSROO7Dec 17, 2019Guide
Thx Fraser i’ll Give it one last go lol, so the xr series don’t do vdsl, any other recommendations gaming router ps4.
- Netduma-FraserDec 17, 2019NetDuma PartnerLet us know how you get on! It should work with all connection types as you'll just be connecting it to a modem or router so I think what I suggested should work.
No worries Fraser if I will do, just one thing the laptop I’m using to acsess rx300 has no Ethernet so I have to use wireless, could that cause any issues, as I know if I could acsess it hard wired would be much easier, most of the time I can’t even get the Dumas screen so frustrating mate, think it’s a dns issue I have to turn the tp link off and back on seems random just to even get the screen to be displayed. Like I said before after hours of getting nowhere I tried netgear support and some guy tried to use remote acsess to solve issue, said that there are loads of foreign ip addresses on my network causing confusion and that may be the reason I’m finding it hard to get into the router settings, also said that’s the reason I’m finding gaming laggy, but surely if I game with wireless turned off and only have hard wired Ethernet cable can’t my PS4 be only thing on my network. I have checked devices and everything seems ok.
- Netduma-FraserDec 18, 2019NetDuma PartnerJust to confirm when you're in this setup the TP Link doesn't have WiFi broadcasting does it? What does he mean by foreign IP addresses though - have you got an example?
- JAMSROO7Dec 18, 2019Guide
Bro, he basically took control of the laptop through something called fix me, and came to the conclusion that I had a lot of foreign ip addresses on my network and these were causing the problem, said to look would be free but if I wanted to fix it would be 149! I said I couldn’t pay but thanks for looking. This sounded strange to me, I thought if I check my network and can only see what devices I have on that’s that, and if I turn off wireless while playing how can anything be on my network accept wired ps4. I’ll send some pics bro, let me know if anything looks out of the ordinary, i’ll Try your method tommorow let you know how I get on
- Netduma-FraserDec 18, 2019NetDuma PartnerCan't see the pictures at the moment as they need to be moderated but will take a look and let you know what I think.
Thank you much appreciated.
- Netduma_AlexDec 19, 2019NetDuma Partner
Doesn't look like your device has a bridge mode. That's a shame.
Might have to go through the DMZ route.
Also this guy that connected remotely to your PC and then asked for money? That sounds really dodgy to me. I wouldn't trust what he said.
FYI nobody from Netduma support will ever ask you for money.
- JAMSROO7Dec 24, 2019Guide
NO joy I have officially 100% given up, for the second time lol. I can’t get a decent connection now even with just the tp link if you look at the top of pic you can see tiny red dots would these affect gaming as my signal now is sooooooo sloooooooow and completely useless for gaming, once more thx for all your input guys, i’ll Post router stats, can anyone tell me if they don’t look right. I may have been put on interleaving and not on fast path, all I can think of.
- Netduma-FraserDec 24, 2019NetDuma PartnerCan't see the dots in the picture you're referring to and these pictures haven't been moderated yet. Did you manage to try the DMZ? An alternative would be to do port forwarding 1-65535 TCP/UDP to the router. Also it does look like it has wireless so disable that and then make sure all devices are connected through LAN or WiFi to the router.
If you zoom in bro, there at the top of the graph evenly spaced out tiny red dots dots. I’m putting it on eBay, the Rx300. Hope I can grab a vdsl one with the same features.
- Netduma-FraserDec 24, 2019NetDuma PartnerI zoomed in as much as possible, can't see what you're referring to. Sorry to hear that, the only routers with these features are the XR routers or our own router, none as specifically vdsl and should work just fine with it regardless. When you got support before did you go directly through the Netgear support link and make a ticket? If not I would suggest doing that.
If you look about an inch to the right of the long red line, you can see tiny red dots at the top of the graph, there’s 7 in total. So there is no Dumas router vdsl, that’s a shame.
- Netduma-FraserDec 24, 2019NetDuma PartnerRouters unlike modems don't tend to be connection specific as they're connected to a modem and so will work with any connection. I would suggest you make a direct ticket with Netgear as this is more their area of expertise.
No worries i’ll Do that
