m0ngr3ll
Apr 04, 2020Tutor
XR300, Vigor 130 & Sky Broadband. No internet.
Hello, I’m going absolutely crazy trying to set up my network and I’m hoping someone has the answers to my problems! I will start by saying Networking is not my strong point. I’m trying to use a...
Netduma-Fraser
Apr 05, 2020NetDuma Partner
I believe you'll need to select requires a login on the XR internet page, then use these details for username and password. Then apply and reboot just to be sure, do you get a connection then?
User: ee11fb12@skydsl
Pass: 80d677a6b2b78be
- m0ngr3llApr 05, 2020TutorStill no luck after trying to the login details unfortunately, still showing as 0.0.0.0
I believe as I’m on Sky and using the Vigor 130 I need the connection to be DHCP but I can only choose between PPTP, PPPoE and L2TP on the Internet setup page. Just to make sure I haven’t made a mistake, the Ethernet from the Vigor 130 should be plugged into the yellow WAN port of the XR300, right?- Netduma-FraserApr 05, 2020NetDuma PartnerIn Internet Setup just say you don't need a login and it will go back to using DHCP. Yes that's right. This video from one of our users with Sky may help https://www.youtube.com/watch?v=BdcsmYX7eEQ
