m0ngr3ll
Apr 04, 2020Tutor
XR300, Vigor 130 & Sky Broadband. No internet.
Hello, I’m going absolutely crazy trying to set up my network and I’m hoping someone has the answers to my problems! I will start by saying Networking is not my strong point. I’m trying to use a...
m0ngr3ll
Apr 05, 2020Tutor
Still no luck after trying to the login details unfortunately, still showing as 0.0.0.0
I believe as I’m on Sky and using the Vigor 130 I need the connection to be DHCP but I can only choose between PPTP, PPPoE and L2TP on the Internet setup page. Just to make sure I haven’t made a mistake, the Ethernet from the Vigor 130 should be plugged into the yellow WAN port of the XR300, right?
Netduma-Fraser
Apr 05, 2020NetDuma Partner
In Internet Setup just say you don't need a login and it will go back to using DHCP. Yes that's right. This video from one of our users with Sky may help https://www.youtube.com/watch?v=BdcsmYX7eEQ
