Kyboy89
Mar 06, 2020Aspirant
Xr300 with a vpn
Does this router have any updates for vpns? I am trying to set up a VPN for my xbox one x .
- Netduma-FraserNetDuma PartnerAre you referring to adding more VPN providers? Not currently but you are able to add your own VPN provider using an OpenVPN config file from the provider and the advanced section of Hybrid VPN.
- Kyboy89AspirantWell I just want to set up a VPN for entire network. Mostly for my xbox one x. I understand you can config the router for such or go through a computer to do this. I bought this model xr300 before realizing this. So i was trying to find out if there are upgrades out now for it to set up a vpn that i would subscribe for. It seems if no updates are out I need the xr 500 to do this?
- Netduma-FraserNetDuma PartnerUnderstood, yes you'll need to get one of the other XR routers on offer as it's not available at this time for the 300.
