RME9632
May 18, 2020Tutor
Xr300
Hello guys. I have the xr 300 router and d7000v2 modem router. I set the d7000v2 as modem only and connect it to xr300. Everything works flawlessly i have a rock solid internet everywhere except this unusual problem. When i connect to PlayStation 4 i have internet ok but it wont let me to login to psn network it says failed. When i swap the d7000v2 with my isp modem router combo everything is ok with PlayStation 4. I have a second public ip adress assign to xr300 because i use the ppoe passthrou and the credentials setup to xr300 and to my isp modem router because i want to keep the voip phone i cant bridge my isp modem router.
I think its not reladed to xr300 probably its the modem part of the d7000v2.
Its drives me crazy.
As for the part regarding the unit xr300 its shelf, the performance is rock solid. No lockdowns no random reboots no drop outs no nill values anywhere nothing at all, and the sofware part the dumaos its outstanding everything work as it should be.
I am atlatest firmware 1.0.3.38_10.3.30
I am very curious why there are so much problems there in the forum regarding these units xr300 xr500 and xr700 is the QC of netgear is poor or iam the lucky guy that i have a non deflective unit or my network structure benefits the xr300.
I live in greece athens with vdsl2 100/10mpps
- Netduma-FraserNetDuma PartnerAre you using the Geo-Filter? If so switch to Spectating Mode, does that allow it to connect properly?
- RME9632TutorHello Fraser and thanks for your reply.
Its probably not related to xr300 at all, because if i put ps4 directly to d7000v2 as modem and setup a ppoe connection to ps4 i have internet on ps4 but it won't let me connect to psn. With my isp modem/router combo and xr300 everything works flawlessly. Question: is dumaos geofilter support pro evolution 2020?
I am asking this because i have came around with all possible settings combination and no matter i change always show me ping 38- 42ms and the only thing showing in the map is two servers one in japan and one in united States. Its impossible to have from here in greece 38ms ping among these locations- Netduma-FraserNetDuma PartnerThat is really weird, perhaps PSN is down in your area. We haven't specifically tested the game but it should work in theory. They will be mislocated on the map and are actually much closer to you.
