prozema
Feb 04, 2019Initiate
XR450 - This R-App is not loaded yet, please try again in a minute.
I am having an issue where I attempt to bring up my DumaOS interface by going to routerlogin.net and I am seeing the error "This R-App is not loaded yet, please try again in a minute." on my Netgear ...
Netduma_Jack
Feb 05, 2019NetDuma Partner
Hi there - I recommend you factory reset the router to see if that clears the error message: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
DRU732
Jun 06, 2019Tutor
??? Really? Nuke all your router settings for this issue? Lazy troubleshooting or poor OS design if that is the first and only solution offered.
I will lose:
- DHCP reservations
- Individually labeled devices (rather than Unknown Device)
- Categorized devices (Phone, PC, Printer, other...)
- DDNS settings
- VPN Settings
- Port Forwarding settings ..
I upgraded from 2.3.2.32 to 2.3.2.40 and now half of the R-Apps are broken.
Can I at least restore my config after doing the full reset? or will that also restore the problem?
- Netduma-FraserJun 06, 2019NetDuma PartnerA factory reset is a standard troubleshooting step and one that should fix the issue. Yes the config should be fine to restore as it'll just cover settings that have been changed, shouldn't trigger the issue.
