qluri
Aug 26, 2020Aspirant
XR450 Dropping Internet
I have a Cm1000 modem hooked up to my just delivered yesterday xr450 gaming router. Yesterday the connection was great and never dropped a single time. Today everyone is using it for school and work and it has dropped internet about 5 times.
- Netduma-FraserNetDuma PartnerDo wireless and wired devices both go down? If you connect direct to the modem is the connection down as well?
- qluriAspirantThe modem only has 1 ethernet port so I can't test going through the modem and checking dropped wireless at the same time.
- Netduma-FraserNetDuma PartnerIf you unplug the router you could do it that way but appreciate it isn't ideal. Does the connection regain itself or do you need to reboot? Take a look in System Information at the log panel, are there any entries that line up with the disconnects?
