Andrewbrown615
Jan 07, 2020Initiate
XR450 Gaming Router Apple Product Issues
Hello all, I have recently upgraded to an XR450 Nighthawk Gaming Router for our home. We were having signal issues so I upped our coverage with this new router. I have been having issues w...
Netduma-Fraser
Jan 08, 2020NetDuma Partner
Smart Connect is a feature that combines both 2.4 & 5GHz into one WiFi network and then the router switches devices between 2.4 or 5GHz depending on their need. All you need to do is disable Smart Connect in the WiFi settings and you'll then see you can connect manually to 2.4 or 5GHz. Let us know if connecting to 5 works better.
Andrewbrown615
Jan 08, 2020Initiate
Perfect! I am new to all of this so thank you for pointing that out for me. That is exactly what I needed!
