XxMitakxX
Dec 10, 2019Follower
XR450 Intenet problem
I just got a new XR450 Gaming Router and I connected it to the internet at my home via cabel. I can connect to it via wifi or ethernet but the devices don't have internet (Connected - No Internet). T...
Netduma_Alex
Dec 10, 2019NetDuma Partner
Thanks for buying an XR450!
So first let's just make sure it's all connected correctly. The XR450 isn't a modem, so with most internet connections you will require a modem. Your ISP should have provided a modem (a box that sits between your router and the wall).
The other thing we need to know is wether your connection requires a login or not. This isn't common for fibre connections but it's possible.
If you let me know what your Internet Service Provider is, I might be able to look up some details to help you out.
