Toolguns
Sep 01, 2019Aspirant
XR450 Nighthawk - Slower speeds than my default Spectrum Modem?
I'm having issues with internet speeds using my new XR450 Nighthawk Router and would like some help in figuring out what is happening. 1. First time I installed it and configured through DUMAS,...
- Sep 17, 2019Even more so I think this is due to your PC ethernet adapter, I'd even suggest perhaps replacing this (if possible) or finding a 1gps USB to ethernet adapter and testing with that (could take back for refund if it doesn't work) and see if that is the cause. The only device this is happening on is that one so that is where I would look first. You can get higher than you pay for sometimes, depends on the demand in the area usually. Yes possible their modem locked speeds down as well.
Toolguns
Sep 20, 2019Aspirant
Thanks for the advice... I'm not very PC savvy, but I'll see if my friend that help me build this Gaming PC can make some time for me sometime and we'll see about sending it in for warranty if Asus will take it in...
Question, I marked one of the answers as as the solution.... I'm not sure if that sets the thread as "solved"... I'm new here =)
Sep 20, 2019Guru - Experienced User
Good, yes check out any kind of warranty as well. I believe ASUS has some after warranty services as well if this is a high end motherboard. Something i'd want to keep maintained.
Yes. It's marked now.
Thank you.
ps. if you need more wifi coverage at some point from the XR, the EX7700 does a great job and works well with the XR450. I have two and have great coverage and performance.
- Netduma-FraserSep 21, 2019NetDuma PartnerFantastic to hear that, happy to hear it is solved. Do let us know if you have any further questions!
