MLask
Jun 27, 2019Aspirant
XR450 Nighthawk wifi router
XR450 Nighthawk wifi router need help connecting to Comcast modem. Modem connects well directly to decktop computer but not when ethernet goes first to previously setup router
Netduma_Alex
Jun 28, 2019NetDuma Partner
Have you got your router set to use DHCP in Internet Setup?
It might be a good idea to connect your modem to your router, and then do a factory reset. This will run through the setup procedure again and hopefully detect your internet connection correctly.
