MLask
Jun 27, 2019Aspirant
XR450 Nighthawk wifi router
XR450 Nighthawk wifi router need help connecting to Comcast modem. Modem connects well directly to decktop computer but not when ethernet goes first to previously setup router
MLask
Jun 29, 2019Aspirant
Comcast and IE10
Modem = Arris TM722G
Netduma-Fraser
Jun 30, 2019NetDuma Partner
Have you tried the suggestions mentioned so far as they should resolve your issue.
- MLaskJun 30, 2019Aspirant
unable to try, after reset button pushed had no internet access
I have an old computer with only one ethernet connection, and a modem with only one ethernet output
once signal at modem if I plug eithernet from modem to computer Comcast internet works fine,
but if goes from modem to router and then by ethernet back to computer, nothing works and no wifi in house
I do have an apple IPHONE 7 and it has a hotspot
is there a way to reset modem by phone?
Re: XR450 Nighthawk wifi router
I have an old computer with only one ethernet connection, and a modem with only one ethernet output once signal at modem if I plug eithernet from modem to computer Comcast internet works fine, but if goes from modem to router and then by ethernet back to computer, nothing works and no wifi in house
is there a way to reset modem by phone?- Netduma-FraserJun 30, 2019NetDuma PartnerIf it is a true modem then you wouldn't be able to factory reset it from a phone as it wouldn't have WiFi. Do you know if you require PPPoE at all?
