Billyfair
Aug 10, 2018Tutor
XR450 not giving full speeds on 2.4GHZ band
Just bought an XR450 from Costcon on sale and relized it is not giving my full speeds on the 2.4GHZ band. I should be getting 100 down but instead i'm getting 80 down on this new router. My old Asus ...
Aug 11, 2018Guru - Experienced User
Using a Mac Mini, it's wifi reports connecting at 195-220Mb on 2.4Ghz and 450Mb on 5ghz which I believe thats the Minis max connection rates.
2.4Ghz
http://www.speedtest.net/result/7544634184
5Ghz: http://www.speedtest.net/result/7544637056
2.4Ghz
Connecting my D-Link DWA-192 to the Mini: http://www.speedtest.net/result/7544623459
Possible APPLE wifi issue with 2.4Ghz and the 450...
Billyfair
Aug 11, 2018Tutor
I am not using an Apple prodcut to test the speeds.
- Netduma-FraserAug 12, 2018NetDuma PartnerDid you use a WiFi analyser to find the least congested channel to change to? Do you have another device to test 2.4GHz wireless speed on?
- BillyfairAug 12, 2018Tutor
I have done all of that.
- Netduma-FraserAug 12, 2018NetDuma PartnerWhat results did you get on other devices? May be the device doesn't support mu-mimo or beamforming so could disable those in Advanced WiFi settings. Otherwise would recommend contacting Netgears 24/7 support line
- FURRYe38Aug 12, 2018Guru - Experienced User
What devices
are you using to test 2.4Ghz?- BillyfairAug 12, 2018Tutor
Pixel 2 XL and Nexus 6P
