Billyfair
Aug 10, 2018Tutor
XR450 not giving full speeds on 2.4GHZ band
Just bought an XR450 from Costcon on sale and relized it is not giving my full speeds on the 2.4GHZ band. I should be getting 100 down but instead i'm getting 80 down on this new router. My old Asus ...
Billyfair
Aug 11, 2018Tutor
I am not using an Apple prodcut to test the speeds.
Netduma-Fraser
Aug 12, 2018NetDuma Partner
Did you use a WiFi analyser to find the least congested channel to change to? Do you have another device to test 2.4GHz wireless speed on?
- BillyfairAug 12, 2018Tutor
I have done all of that.
- Netduma-FraserAug 12, 2018NetDuma PartnerWhat results did you get on other devices? May be the device doesn't support mu-mimo or beamforming so could disable those in Advanced WiFi settings. Otherwise would recommend contacting Netgears 24/7 support line
