Billyfair
Aug 10, 2018Tutor
XR450 not giving full speeds on 2.4GHZ band
Just bought an XR450 from Costcon on sale and relized it is not giving my full speeds on the 2.4GHZ band. I should be getting 100 down but instead i'm getting 80 down on this new router. My old Asus ...
Aug 13, 2018Guru - Experienced User
Wanted to try a older 2.4Ghz 450Mb N only wireless adapter. TrendNet TEW-687GA.
Beamforming, SC and MIMO enabled on the XR450:
With SC and MIMO disabled on XR450:
With SC, MIMO and Beamforming disabled on the XR450:
Beamforming and MIMO enabled on the XR450:
Billyfair
Aug 13, 2018Tutor
The crazy thing is it doesn't even let me contact support when I enter my serial number on the website. It is just a blank field and doesn't let me click anything.
