Billyfair
Aug 10, 2018Tutor
XR450 not giving full speeds on 2.4GHZ band
Just bought an XR450 from Costcon on sale and relized it is not giving my full speeds on the 2.4GHZ band. I should be getting 100 down but instead i'm getting 80 down on this new router. My old Asus ...
Netduma-Fraser
Aug 16, 2018NetDuma Partner
I've contacted Netgear Dev/Testing team to see if they can reproduce it
Aug 26, 2018Guru - Experienced User
Have you heard anything back from NG about this?
- Netduma-FraserAug 29, 2018NetDuma PartnerDo you know if the devices with the issues had a Qualcomm wireless chip in them? I haven't heard anything yet but just got back from holiday so will catch up with everything.
- BillyfairAug 29, 2018Tutor
Both devices I used did have a Qualcomm chip in them.
- Netduma-FraserAug 29, 2018NetDuma PartnerIf you ever get a chance or for anyone else with the same issue change the wifi adapter to use AC or if it doesn't support AC then b/g instead and see if that resolves the issue.
