trav9996
Dec 26, 2020Tutor
XR450 Port Forwarding not working
Hoping someone can help because I'm at my wits end trying to get my home security system working with the Nighthawk XR450. I have an Amcrest 8 camera DVR system setup that has worked just fine with ...
- Dec 28, 2020It is a modem so should be no issues but I've just seen that it does have QoS on it so could you disable that please and then reboot the XR and see if it works.
Netduma-Fraser
Dec 28, 2020NetDuma Partner
How is the router setup with your modem/router to get an Open NAT exactly?
- trav9996Dec 28, 2020Tutor
Within the XR450 Duma OS, I click on Settings, then WAN Setup, then NAT Filtering set to Open. Again that was just a guess based on some other threads for other routers. It is still not allowing the video signal through to the app on my phone unless I am connected to the local wifi network for the router that the DVR for the security system is connected to.
- Netduma-FraserDec 28, 2020NetDuma PartnerWhat is the XR450 connected to? - What is it getting internet from - is it a pure modem or does it have WiFi as well?
It is connected to a Netgear CM500 modem. I would have thought they would work well together, but obviously I'm missing something. Reading now that they may not be bridged properly for NAT? But I do have an older, slower router that works just fine with the CM500. No issues getting port forwarding to work. Not sure what's the deal with the CM500 / XR450 combo.
