RickyOG90's avatar
RickyOG90
Follower
Sep 07, 2020
XR450 rebooted and now the Ethernet leds rapidly flash and the power LED flashes every second
So as the subject states, but to elaborate further, I was having an issue with accessing my files on my readyshare storage, so I unplugged my NetGear XR450, gave it about 30 seconds, then plugged it back in. However, unlike every other time, this time the ethernet LEDs began rapidly flashing. I would say about 3 flashes per second continuously. After a couple of seconds, the power LED went from the initial orange to white but flashing white about 1 flash per second continuously as well. After leaving it go for a few minutes, there was no change so I rebooted it again but kept it unplugged for a minute, and still same issue. I even resorted to holding the reset button to no change. Googling, I get very little information with only a possibility that the firmware got corrupted, but how? I wasn't updating the firmware(I know I was on firmware v2.3.2.56). Worst part is my hardware warranty expired literally a month ago.
Any help is much appreciated. I really do not want to buy another router, specially since the XR450 is like $300, and the XR500 is $200 but out of stock until october.
  • Do you have internet or access to the interface when the LEDs are behaving this way or are you assuming there is an issue?
  • FURRYe38's avatar
    Any progress on this?
