McRob1
Sep 03, 2020Luminary
XR450 Router Having Connection Issues
My XR450 with firmware vertion 2.3.2.56 is having connection issues. My computer is connected using a eithernet connection and yesterday I was not able to connect to most web sites. I could connect...
Netduma-Fraser
Sep 04, 2020NetDuma Partner
For the website issue change your DNS in Internet Setup and see if that helps. For Rapp not loading - go to System Information and in the Rapp panel options change the number of retries to 5 and reboot the router - see if that helps.
McRob1
Sep 06, 2020Luminary
I have determined that the Router was overloaded. A new neighbor moved in near my house and was broadcasting on the 5Mhz freequency using the same channel 157 that I had set a couple of years ago. I did some research and found out that I could use my Apple Computer to do a scan of all the wireless devices in my neighboor hood. I found a channel that was not being used by anyone close and set the Router on that channel. The router is now back to normal and actually works again.
I still wonder why it couldn't handle some wifi interference and went into overload.
Thanks for answering my question.
- FURRYe38Sep 06, 2020Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything when you have wifi neighbors hear by. Under Advanced Tab/Advanced Settings/Wireless Settings
Enjoy,
