Driftdee
Mar 15, 2021Tutor
XR450 Strict NAT type
Netgear Nighthawk XR450 router in perfect contition, on the latest officially released firmware. had it for about a year. my router is setup to prioritze my Gaming PC and i have ports open for xbox l...
Netduma-Fraser
Mar 16, 2021NetDuma Partner
What is the model of the modem/router the XR is connected to? Have you done anything on that to ensure all traffic flows straight through to the XR?
- DriftdeeApr 07, 2021Tutorthe model of the modem, i have no idea, cause it's not a modem, it's just a pass-through. I've done everything in my power to ensure that everything is flowing as it should. one of my devices is indeed getting open NAT, but i can't close the NAT of that device to get my Main PC to get open NAT again. not sure what to do...
- michaelkenwardApr 07, 2021Guru - Experienced User
Driftdee wrote:
the model of the modem, i have no idea, cause it's not a modem, it's just a pass-through.That's not much help. What is "a pass-through"?
The Internet always comes from something. If it is a simple Ethernet "hole in the wall", that is connected to something further down the line.
That thing may well be a router of some sort. (It often is.) And that complicates the picture.
If you don't know what the box is, explain how you get the Internet. Maybe someone can guess as to what is going on.
- Netduma-FraserApr 07, 2021NetDuma PartnerDisable the DMZ and port forwarding that you have done and in WAN Settings just set NAT to Open.
