ZiosEvolution
Aug 16, 2021Follower
XR450 "This R-app not loaded yet, please try again in a minute"
This is for the router xr450, not the 500. I have upgraded and downgraded to each firmware for the xr450 nighthawk router, but have not found a solution to why I cannot acess the netdumaOS. I clear...
michaelkenward
Aug 16, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
