ZiosEvolution
Aug 16, 2021Follower
XR450 "This R-app not loaded yet, please try again in a minute"
This is for the router xr450, not the 500. I have upgraded and downgraded to each firmware for the xr450 nighthawk router, but have not found a solution to why I cannot acess the netdumaOS. I clear...
Netduma-Liam
Aug 16, 2021NetDuma Partner
Thanks for posting!
We've noticed the issue in your screenshot occasionally, but this only occurs immediately after an upgrade and is normally fixed after a few minutes and a browser refresh.
Are you factory resetting the XR450 after installing new firmware? That's usually a step we recommend too as it means you're starting from a clean slate.
How are you connected to the XR, via wired or wireless? Are you trying to access the admin page from a laptop/desktop? We suggest this as the interface can be a little buggy in a mobile browser.
