VoidConcept
Oct 17, 2019Follower
XR450 Vlan setup
I'm trying to setup a VLAN with my router, but have been having some issues with it. What I'm trying to accomplish is have two networks: one for my computer/phone/etc, and another for IoT devices. Id...
Netduma-Fraser
Oct 19, 2019NetDuma Partner
You're not using the standard entry in the tag group are you? As that could cause it if you don't need VLAN for a WAN connection. Also have you set up VLAN on the devices you want to connect as you may need to do this.
