Noahh's avatar
Noahh
Guide
Jan 08, 2020
XR450
So I got my XR450 about a week ago and my WiFi or lan has never been good but for some reason I’m getting extremely slow speeds while updating/downloading something on my pc. Yes I’m using Powerline adapter and I’m not sure if that’s the reason or if it’s something with my router
  • How is your XR450 connected to the internet? Are you using a modem or an upstream router?
    Also, what are your QoS settings currently?
    • Noahh's avatar
      Noahh
      Guide
      I am using wired and 50 percent is going to my pc and I’m still 60 ping in game and when I do a speed test its saying it’s good but when I’m downloading something I’m getting less than a megabyte
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        First thing to check would be to do a test on the powerline adapter and then one directly to the router to see if the adapter is causing any slowdowns. Secondly, have you put your expected speeds in the bandwidth settings in the Anti-Bufferbloat options? Then use 70/70 for Anti-Bufferbloat, are you also using the Geo-Filter to get close servers?
