Greenhorn64
Nov 08, 2021Aspirant
XR4500 Slow down at router
Hello. I'm having a issue with my internet speeds. I have had this set up for over 1 year things have been great. All the sudden my speeds dropped from 300Mbps down to 158Mbps with upload speeds of 13...
Netduma-Liam
Nov 09, 2021NetDuma Partner
The firmware you're on is up-to-date, it was released a few days ago.
Were are you measuring these speeds, through Connection Benchmark or through a third-party speedtest? Could you run both and compare their results?
Greenhorn64
Nov 09, 2021Aspirant
I have ran both 3rd party from speedtest.net and the bench the mark test in Dumaos. They both are really close to one another. Last night I played around with Qos and Geo Filter and was able to clean up some gaming lag but its still noticeable.
- Netduma-LiamNov 09, 2021NetDuma Partner
OK thanks for confirming that.
After playing with QoS, are you speeds still as low as before? If you completely disable QoS from the three-line menu in Congestion Control, do you speeds return back to full?
- FURRYe38Nov 09, 2021Guru - Experienced User
Where what I got with my XR450:
Both QoS enabled and disabled.When QoS is enabled, I have the sliders set for 99% on both. Since i'm the only one gaming online now days and mostly at night while others are sleeping, no need for lots of bandwidth management here.
