ClickBait
May 04, 2021Tutor
XR500 — Nighthawk Pro Gaming Router does it support fiber optic
i was wondering if this router support fiber optic or not before it buy it. Only reason is my current router keeps going out randomly not the motem just the router
- May 05, 2021
Try installing firwmare version 1.0.9.42 to the R7000. Then do a factory reset and a new install (don't use a backup configuration)
May 05, 2021Guru - Experienced User
Most fibre companies give you an ONT or a gateway to convert from fibre to ethernet.
That's what you'd connect the XR to.
What current modem is your current router connected to?
its possible that its just a settings issue.
- ClickBaitMay 05, 2021Tutor
yeah all they gave us was they put in the cord and pluged it into the motem then into the router and left
here you go
Can you see that if not just send me your email and ill send it to you through that
- Netduma-FraserMay 05, 2021NetDuma PartnerCan't see the picture, you will have to attach it directly otherwise take a look on the underside of the modem and it will tell you the model. If the modem has a LAN ethernet port then the XR can be connected to it.
