ClickBait
May 04, 2021Tutor
XR500 — Nighthawk Pro Gaming Router does it support fiber optic
i was wondering if this router support fiber optic or not before it buy it. Only reason is my current router keeps going out randomly not the motem just the router
- May 05, 2021
Try installing firwmare version 1.0.9.42 to the R7000. Then do a factory reset and a new install (don't use a backup configuration)
May 05, 2021Guru - Experienced User
Most fibre companies give you an ONT or a gateway to convert from fibre to ethernet.
That's what you'd connect the XR to.
What current modem is your current router connected to?
its possible that its just a settings issue.
