ClickBait's avatar
May 04, 2021
XR500 — Nighthawk Pro Gaming Router does it support fiber optic
i was wondering if this router support fiber optic or not before it buy it.   Only reason is my current router keeps going out randomly not the motem just the router
  • plemans's avatar
    May 05, 2021
    Try installing firwmare version 1.0.9.42 to the R7000. Then do a factory reset and a new install (don't use a backup configuration)
