noz79
Nov 23, 2023Aspirant
XR500 - APEX LEGENDS ON PS5
Hello, good day to you. I have an XR500 connected to a CM1200. What would be the best set up for Apex Legends on PS5? I have tried the Geo Filter, but it will only work if the game will sele...
Netduma-Fraser
Nov 23, 2023NetDuma Partner
I can't see your screenshots but I think that's the way the game matchmaking works unfortunately - it doesn't restart the search. What is the average ping on the Geo-Filter compared to in game?
noz79
With the server the game assigns me to, the ping on the Geo-Filter shows 54 but I've been receiving an in-game ping of 70-90 on average.
- Netduma-FraserNov 23, 2023NetDuma PartnerThat difference is processing delay, 70 would be okay but the 90 would be high - indicates the server is under load. Does the server selection on the game match where your Geo-Filter radius is covering?
- noz79Nov 23, 2023Aspirant
95% percent of the time, it is not within the Geo-Filter.
- Netduma-FraserNov 23, 2023NetDuma PartnerIt may be the servers are mislocated on the map when that happens, if you disabling Filtering Mode so you can still see and ping servers on the map and just let the game decide (after selecting your server on the game), regardless of where the server appears on the map ping it, does it show a ping you would expect for the server you selected in game or is it too high?
