darkmage0707077
Sep 18, 2019Initiate
XR500 - Brave Browser broken after firmware update
I just recently updated my firmware to the latest version 2.3.2.56, with no apparent issues. However, after attempting to log back in several days later, I find that the router website no longer work...
- Sep 19, 2019
so it works fine with other browsers but not your brave browser?
If brave is based on chrome, there was issues with chrome doing this same thing with a recent update to chrome.
Sep 19, 2019Guru - Experienced User
Have you rebooted the PC or device that your broswer is installed on and tried again after the reboot?
darkmage0707077 wrote:I just recently updated my firmware to the latest version 2.3.2.56, with no apparent issues. However, after attempting to log back in several days later, I find that the router website no longer works with the Chrome-based Brave browser: I will VERY briefly see the usual login menu appear and disappear, where it then takes me to the "cannot authenticate" page that normally appears when you supply bad passwords or cancel out of the prompt (where it requires the router S/N to continue).
I've tried everything from clearing my browser cache to restarting my machine to resetting the router to a full factory reset, and nothing works. The prompt appears fine on other browsers such as Firefox, and it WAS working fine with the previous edition.
Is it possible to roll back to the previous firmware version?
Netduma-Fraser
Sep 19, 2019NetDuma Partner
The link from plemans will likely resolve the issue. We are working on getting that fixed as well.
You are able to downgrade the firmware without issue but that's not the problem here.
- Netduma_AlexSep 20, 2019NetDuma Partner
Yes I believe that Brave is based on Chromium, however I don't know if it has the same developer toggles that Chrome has. If you can, you need to disable http-auth-committed-interstitials
