Androgap
Jun 14, 2020Tutor
XR500 - Brick
Hi, all ! Not long ago when I returned home, I found that my router was not working. The power button is constantly red. The reset button didn't help.When connected to the LAN port, the correspon...
Netduma-Fraser
Jun 14, 2020NetDuma Partner
Just to clarify, once you get it working a reboot makes it broken again? When you get it working could you try a factory reset and see if that helps at all?
