Androgap
Jun 14, 2020Tutor
XR500 - Brick
Hi, all ! Not long ago when I returned home, I found that my router was not working. The power button is constantly red. The reset button didn't help.When connected to the LAN port, the correspon...
Androgap
Jun 15, 2020Tutor
When indicator is blinking white, button RESET don’t effectively. Nothing is happening. Now I'm leaning towards the fact that the problem is in the hardware.
Netduma-Fraser
Jun 16, 2020NetDuma Partner
The TFTP method can be tricky to get working as the timing is important, you've mentioned programs for TFTP there, did you use TFTP via Command Prompt that is what I have used before.
- AndrogapJun 16, 2020Tutor1. Using the tftpd64 and TFTP2exe programs when the router restarts with the RESET button clamped, the firmware is visually loaded. But there is no effect. If the timings were not correct, TFTP gave an error. Correct me if it’s not. 2. Windows TFTP client gives an error - it is not possible to download the file " firmware name” 3. If need I can create foto/video.
- Netduma-FraserJun 16, 2020NetDuma PartnerThat's fine, I would recommend you contact Netgear directly here: http://support.netgear.com/ in order to get a replacement or contact the retailer you purchased from as it sounds as though the router is faulty.
- AndrogapJun 16, 2020TutorFraser, thank you for your feedback and advice.
