Androgap
Jun 14, 2020Tutor
XR500 - Brick
Hi, all ! Not long ago when I returned home, I found that my router was not working. The power button is constantly red. The reset button didn't help.When connected to the LAN port, the correspon...
Netduma-Fraser
Jun 16, 2020NetDuma Partner
That's fine, I would recommend you contact Netgear directly here: http://support.netgear.com/ in order to get a replacement or contact the retailer you purchased from as it sounds as though the router is faulty.
Androgap
Jun 16, 2020Tutor
Fraser, thank you for your feedback and advice.
