elCuculuz
Oct 11, 2022Apprentice
XR500 - Constant reboots despite resetting the router multiple times
Same here, constant reboots despite resetting the router multiple times, flashing a older FW doesn't change anything. Most of my panels options in the router won't load and give a error not available...
Netduma-Fraser
Oct 11, 2022NetDuma Partner
In most cases where the router is in a reboot loop it's that it's not getting power properly - if it's connected to an extender try direct to a wall outlet, if that doesn't work then try another power adapter if you have it with similar voltage.
Also if you're having a hardware issue like that its always best to make a ticket direct with Netgear.
