elCuculuz
Oct 11, 2022Apprentice
XR500 - Constant reboots despite resetting the router multiple times
Same here, constant reboots despite resetting the router multiple times, flashing a older FW doesn't change anything. Most of my panels options in the router won't load and give a error not available...
Oct 11, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to set a new DHCP IP address range of .100 to .200 as well from the default range.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser. Be sure to set a new DHCP IP address range of .100 to .200 as well from the default range.
Press the back reset button for 15 seconds then release.
