devi343
Sep 02, 2020Tutor
XR500 - Ethernet doesnt have a valid Ip configuration
So I bought this XR500 roughly a month ago. When it works it works great. The issue is it will randomly disconnect the internet from everything wireless and ethernet but the router acts like it does h...
- Sep 02, 2020This is a known issue that will be fixed in the next beta release, I would suggest signing up for the beta if you haven't already for the chance to get an invite to help test: http://www.netgearinnovation.com/dumaos-beta/index.html
devi343
Sep 02, 2020Tutor
Well I am glad to know this is known and a possible fix coming out. Do you have any idea when it will be released for everyone?
Netduma-Fraser
Sep 02, 2020NetDuma Partner
It really depends on how stable the beta is, hopefully this next build will be good and we can look at releasing it more widely.
