Script
Dec 18, 2023Aspirant
Xr500 - higher ping now than compared to my modem
Netduma-Fraser
Dec 18, 2023NetDuma Partner
What is the model of the modem/router? How have you set this up, with XR in the DMZ, modem/bridge mode? Are ALL devices connected to the XR? Are you using Always or Auto Enable for Congestion Control?
Script
Bridge mode from rogers modem, Ethernet cord from modem to router (xr500), router to switch and all devices hardwired with cat 5e and above. Without the router ping is normal. I’ve tried always on with 70% on both sliders didn’t do anything. Tried without any settings just fresh and same results.
- Netduma-FraserDec 18, 2023NetDuma PartnerWhere are you measuring the ping exactly?
