mtthw
Feb 27, 2018Aspirant
XR500 - HomeKit issues
Hello, I have recently installed a XR500 Nighthawk Pro Gaming Router and I have had issues with Apple HomeKit, specifically with my Lutron Caseta Smart Hub. I have serveral other HomeKit devices tha...
mtthw
Mar 01, 2018Aspirant
Hi Fraser,
So, I need both to make it all work. The Lutron Caseta Smart Hub is the only smart hub that talks to the lights that I have in my home. The way HomeKit works is on a local level, unless you have an AppleTV or a iPad configured to be a hub for remote access. This means, that when I am connected to the WiFi on my home network, my iPhone is trying to communicate directly with the Lutron Caseta Smart Hub to control the lights from the Apple Home app. When I turn off the WiFi in my iPhone and I use the same Apple Home app, my phone communicates through the AppleTV to the Lutron Caseta Smart Hub and it all works just fine.
Since the AppleTV is connected through ethernet and not WiFi on the network when everything works, I think that there is something going on with the connection from the WiFi to the ethernet ports in the XR500. Maybe not all of the packets are being transferred between interfaces? I’m unsure.
I have not contacted the phone support yet. This is a extremely technical problem that I didn’t want to try to explain over the phone to someone. Jason N from Netgear PMed me and I have provided contact info to him to help get to the bottom of this. Please let me know if there is anything I can provide you to help you out if you want to look into it further. Thanks for your help!
Netduma-Fraser
Mar 02, 2018NetDuma Partner
Hi Matthew, thanks for the clarification. So it is a WiFi issue essentially?
What I would start by doing is giving your Apple TV a static IP address in Settings > Setup > LAN Setup. It may be that because it will class it as a different device when wired compared to on WiFi that it is getting confused. If you set a static IP this may prevent that. Also are you using Smart Connect so there is only one SSID?
If Jason has further suggestions do let me know!
- mtthwMar 07, 2018Aspirant
I’m sorry it has taken me a little bit to respond, my in-laws have been in town.
I will have to see if assigning static IP addresses will work. I will try that tonight. I am using smart connect for the WiFi with one SSID.
