kelton312
Sep 13, 2018Star
XR500 - Hue Bridge and Shield Built-in Chrome Cast Wired Issues
Hi all, I am having some weird problems with my new XR500.
Scenario: I have an nvidia shield connected via ethernet to the router. I am not able to cast to this device via the built in chromecast,...
Netduma-Fraser
Sep 14, 2018NetDuma Partner
Weird that it only occurs via ethernet and not wireless. In Settings > WAN Setup untick 'Disable IGMP Proxying'. Have you enabled DMZ or done any manual Port Forwarding/Triggering or disabled UPnP?
Do you use PPPoE or VLAN?
- kelton312Sep 14, 2018Star
Do you use PPPoE or VLAN?Thanks for the quick reply,
I tested enabled/disabled "DisableIGMP Proxying", no change.
I have ports forwarded for my plex server and webserver, no triggering or anything out of the ordinary here.
UPnP is enabled, I haven't messed with the defaults for these settings.
- Netduma-FraserSep 14, 2018NetDuma PartnerDisable QoS completely, does that resolve the issue?
It may be the ports you forwared are required for those devices are required for nvidia and phillips but unlikely if they work via wifi. I'd recommend calling Netgear support if QoS disabled doesn't fix it.- kelton312Sep 14, 2018Star
It may be the ports you forwared are required for those devices are required for nvidia and phillips but unlikely if they work via wifi. I'd recommend calling Netgear support if QoS disabled doesn't fix it.Forgot to mention I haven't enabled any QOS or anti buffer bloat settings. Since this router is fairly new I couldn't find anything from other users via google on ethernet to wired connectivity or any similar issues. I will try contacting netgear support and report back if I find anything out.
- schumakuSep 14, 2018Guru - Experienced User
Weird that it only occurs via ethernet and not wireless. In Settings > WAN Setup untick 'Disable IGMP Proxying'.How is the WAN IGMP Proxy involved ? What the OP does describe is all ICMP Multicast on the (W)LAN, respectively between the radio interfaces (all three), the 10 GbE port, the two GbE ports optionally supporting aggregation, and all the other GbE ports. The WAN IGMP proxy would serve for different purposes, typically for provider IPTV applications.
Would switching up the ethernet ports I use make a difference? I haven't tried different ones, I didn't realize they were different speed interfaces.
Sorry for the confusion - ignore the 10 GbE port information, this is applicable to the XR700 only.
