kelton312
Sep 14, 2018Star
XR500 - Hue Bridge and Shield Built-in Chrome Cast Wired Issues
Hi all, I am having some weird problems with my new XR500.
Scenario: I have an nvidia shield connected via ethernet to the router. I am not able to cast to this device via the built in chromecast,...
Myiasis
Sep 18, 2018Star
One more thing to add, the hue bridge is communicating just fine over the internet.
Philips has a web page where you register the bridge. This requires the same pattern as the app is trying to do. You go to the website, hit the Add Brige button, it tells you to push the button on the bridge. This works just fine.
Netduma-Fraser
Sep 18, 2018NetDuma Partner
The only thing that I think could affect it would be DPI and if you disable QoS completely in Anti-Bufferbloats options then it wont affect it. If that doesn't resolve it then it's not a DumaOS issue and maybe something in Settings in which case would recommend calling Netgear support directly.
- MyiasisSep 18, 2018Star
I tried with QOS disabled and the hue bridge still fails to connect.
