kelton312
Sep 13, 2018Star
XR500 - Hue Bridge and Shield Built-in Chrome Cast Wired Issues
Hi all, I am having some weird problems with my new XR500.
Scenario: I have an nvidia shield connected via ethernet to the router. I am not able to cast to this device via the built in chromecast,...
Netduma-Fraser
Sep 19, 2018NetDuma Partner
Okay that's an interesting on, make sure you've got these done: Smart Connect disabled
Advanced Settings > Advanced Wireless > Disable Beamforming and MU-MIMO, ensure HT160 is disabled also.
If that doesn't work let me know and I'll have one more suggestion which I can PM to you.
Myiasis
Sep 19, 2018Star
Looking at my settings, HT160 is disabled, but I do have those other two options enabled. I will be out all day, but I'll try your suggestions later tonight Fraser. Appreciate your troubleshooting help.
