CptWilson11
Apr 08, 2018Follower
XR500 - Keeps dropping Internet
I have an XR500 that has been working fine for the last month and a half, no settings have been changed and all of a sudden the last 2 days the router has been dropping internet (Ethernet and WiFi) and will reconnect then almost a minute or 2 later disconnect again making my home internet useless. Any thoughts or suggestions to remedy this issue?
1 Reply
- Netduma_JackNetDuma Partner
You should try a factory reset to see if that will resolve the issue. You can perform a factory reset via Settings > Administration > Backup Settings > Erase. Please let us know if this resolves your issue.
Please keep in mind that this will clear your settings, but hopefully your connection will stabilise after it :)
