quadrophenic
Jul 22, 2018Apprentice
XR500 - Long Reboot times
Ok, so to start, my shiny and exciting XR500 gaming router is turning into an absolute shambolic nightmare. The thing is plagued with problems. I am hoping for the sake of the community that it is ju...
- Jul 23, 2018
XR500 does not have a modem so why are you rebooting that? Long term rebooting modems all the time will be seen as instability effecting the latency and speeds of your line. As to the other things you mention price really has no bearing, you should see the bugs the R9000 had/has and thats more expensive than the XR500 and the cheaper R7800 has its own issues with blank screens and missing devices in its GUI. Welcome to the world of modern consumer electronics where we are all betea testers in many ways.
As to Game Lag, I dont have that issue but it could be server side depending on the game and the peering points of your ISP play a big part too. Pings are fine for me so far, 8ms to London using the XR500 and 33ms to Germany. Many of your issues on BQM could also be releated to your ISP too as well as your modem being rebooted, or having other issues like the router and the settings you have for your XR500.
IPV6 is being worked on as far as I know and by letting Fraser and Netgear know about other bugs you find they will be fixed in time. The R7800 on relase had major issues with Apple devices and dropping wifi on them and took about four firmware releases to get fixed, Trouble shooting is not always easy, It takes time.
As to the reboot process it is a bit slow, mine does the same light sequence but is up in less than 2 minutes. Have you tried a full factory reset? Then re enter your settings manually, not from a backup. That can sort a lot of issues out. The router should not be talking 5 mins to boot up, but it will be slower as its booting Netgears firmware and Netdumas too. I can't see why you keep rebooting it tbh though. A factory reset will help much more and if you still have issues contact Netgear. However there really is no need to keep rebooting your modem and router so much anyway. What ISP are you with? Also what are your pings like compared with your old router? The more information the better as it hellps build up a picture of your situation.
quadrophenic
Jul 26, 2018Apprentice
Ok so after a full restart and manual configuration it seems my BQM has settled down somewhat. My reported pings in game have not changed but I am getting less connection interuptions and errors.
I will continue to monitor, thank you for your help.
