MBCruise
May 26, 2019Tutor
XR500 - MAC Wireless login to Routerlogin.net
Hi, I cant log in to the routerlogin.net via my wireless macbook. It used to work, but now I cant login to the XR500 and the devices connected to the router. If I use an old Macbook with ethernet ca...
- May 26, 2019
MBCruise wrote:I cant log in to the routerlogin.net via my wireless macbook
Whatever that means - not getting the browser-side login prompt for username & password, username or password not recognized, or the UI not loading, ...?
Any kind of DNSCrypt on that wireless Macbook?
What-if using the default gateway LAN IP (the router LAN IP address) in the browser?
Using the Guest instead of the "normal" wireless?
schumaku
May 26, 2019Guru - Experienced User
MBCruise
May 26, 2019Tutor
Hi, suddenly worked when switching to guest network :-), thx a lot
